1066 Clutch Hydraulic Assist Cylinder Rebuild
Posted by Michael Sheik on July 24, 2006 at 06:38:43 from (199.153.205.246):
My 1066 has the little slave cylinder to assist the clutch disengage. It will weep a little fluid from time to time when the clutch pedal is depressed and held there. Probably 15 to 20 drops. I am still able to disengage and stop tractor and can shift easily with 2 fingers most of time but once in a while when cylinder leaks oil I think it is not completely disengaging clutch which makes for hard shifting. Yea! I know about the little pins in shift linkage and do not want to shear and that is why I want to fix cylinder leak. Also hate oil on floor.
Is the cylinder a booger to get off. Looks like I will need to pull left battery case. Any dos and don'ts here?
