Re: Letter series engine similarity?
Posted by RustyFarmall on July 24, 2006 at 15:10:05 from (216.248.75.180):
In Reply to: Letter series engine similarity? posted by Mike CA on July 24, 2006 at 14:31:38:
I do not own that video, and I haven't watched it, but I can tell you that all of the tractors listed in that ad are so similar that if you have the info needed for one of them, you will be pretty much on your way to rebuild any of them. The Farmall M through the 450 used what is referred to as the "6" series, which includes the W6 and the I6. The Farmall H is of the "4" series, which inludes the W4, I4, 300 and the 350. The "6" series engine is larger than the "4" series, other than that, they are the same.
