Re: ballast or resistor or both?
Posted by arod on July 24, 2006 at 15:15:48 from (130.20.51.229):
In Reply to: ballast or resistor or both? posted by e-manhunt on July 24, 2006 at 14:56:28:
commonly referred to as a "ballast resistor" if I am correct.
I have converted my M to 12 volt.
this is the NAPA porcelein resistor between the coil and the distributor.
there is ALSO an external regulator to put in line, should you not have an alternator with an internal one. this goes between the ignition swith and the F terminal on the alternator, with a dual connection also on the resistor input, doubling up with the input from the coil. I do believe.
Has been a few years. Hope this helps.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
