Re: Brake shaft bearings on H
Posted by Janicholson on July 24, 2006 at 18:56:43 from (66.173.50.153):
In Reply to: Brake shaft bearings on H posted by Rock2000 on July 24, 2006 at 18:44:20:
In a word yes. Do not pry that shaft retainer out. It has a flange that is behind the Bull gear. It will break (as many will attest) The bull gear can be removed from the axle through the PTO mounting hole. Then the axle can be moved to allow the gear to move rearward. This is done routinely to avoid taking off the top cover, but is usually quite a task. Taking the top cover off, then the bull gear and axle is far more direct in being able to see what you are doing. Putting a stethescope (or rubber tube in your ear) on the parts while jacked up and blocked. Might indicate which is making the noise. Be careful, and rotate by hand, not engine. Others may give more advice. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
