Re: Brake shaft bearings on H
Posted by Steven@ND on July 24, 2006 at 19:13:16 from (72.20.78.220):
In Reply to: Brake shaft bearings on H posted by Rock2000 on July 24, 2006 at 18:44:20:
If the brake shaft bearing is bad, you should be able to wobble the brake drum after removing the tin cover...
I broke one of those bearing carriers... no matter because the whole rearend was shot from a bearing going out and running through all the gears.
