Re: ballast or resistor or both?
Posted by texp on July 24, 2006 at 19:49:35 from (70.41.9.93):
In Reply to: ballast or resistor or both? posted by e-manhunt on July 24, 2006 at 14:56:28:
What kind of alternator? If it is a single-wire GM Delco, there is a diode available that plugs into the rear SIDE of the altrnator, keeps from getting a back circuit which might drain the battery when the tractor is not running.
As for a 6 - to - 12 conversion, Inless you replace the coil - and maybe the points and condenser with parts that are designed for 12 volts, you are running the risk of burning them out prematurally. If you place a ballast resister in line with the wire that goes from the switch to the coil, you will effectively be running the engine on 6 volts and the rest of the tractor - mainly lights - on 12 volts. SOME tractors have a wire from the starter solenoid to the coil, giving it an extra boost when starting.
Hope this helps!
Tex
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
