Re: Need Some Advice on a Proper Plow
Posted by CNKS on July 25, 2006 at 17:43:32 from (204.249.178.138):
In Reply to: Need Some Advice on a Proper Plow posted by Mack in Tx on July 25, 2006 at 00:42:01:
If by "offset" you mean a front and rear gang in a V shape, an H will not pull an 8 ft, 5 is more like it, maybe 6, although I have not pulled an offset with an H. For a tandem disk, 8 feet is enough. Janicholson gave you the other info.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
