Re: 400 quits when gets to operating temp.
Posted by Allan In NE on July 25, 2006 at 21:34:06 from (148.78.243.26):
In Reply to: Re: 400 quits when gets to operating temp. posted by old on July 25, 2006 at 21:25:06:
Gotta be something on the primary side of the ignition to be causing his backfire.
Had a car one time that would do that and it turned out to be a condenser screw had come loose.
But, he says it is tempreature related. 'Bout gotta be that coil, me thinks.
Allan
