Re: 400 quits when gets to operating temp.
Posted by Andy Martin on July 26, 2006 at 05:16:44 from (64.219.39.195):
In Reply to: Re: 400 quits when gets to operating temp. posted by Allan In NE on July 25, 2006 at 21:34:06:
Condensers can be temperature sensitive as well.
And they are cheaper.
I almost killed an old man several years ago. He was dragging cedar trees for me with an A with a magneto. The condenser would get hot after about 20 minutes and the tractor would die. It was hand crank and he would crank it and fiddle with it until it cooled and started. He did this all day one day, thinking he was stalling it. When he finally came to the house and told me what he was doing we changed the condenser and fixed the problem.
