Re: wide front for 656 revisited
Posted by Hugh MacKay on July 26, 2006 at 02:00:47 from (216.208.58.189):
In Reply to: Re: wide front for 656 revisited posted by K.B.-826 on July 25, 2006 at 22:00:21:
KB: Read my post, it's nothing more than length of center control arm in relation to spindle control arms. You can make any of the older Farmalls turn shorter by adding 2" to the center control arm. I've seen it done on a 560 and also a Super C.
There is one problem, they are harder to steer and the older power steering like 460 and 560, will not measure up.
