Re: Overdrive for farmall C, super C, 200?
Posted by gene bender on July 26, 2006 at 02:24:39 from (66.43.221.106):
In Reply to: Overdrive for farmall C, super C, 200? posted by A Taylor on July 26, 2006 at 01:29:40:
none was ever made but you could always make one as there is plenty of room to fit one. Have thought about doing that sometime on a B as the same basic tube is used. Dont need a wide front do do that. Just get the steering fixed on the narrow front. We ran the Hs and Ms in roadgear without wide fronts same a s all the other tractors some went fast like SILVER KING without wide fronts.
