Re: wide front for 656 revisited
Posted by Hugh MacKay on July 26, 2006 at 02:29:40 from (216.208.58.189):
In Reply to: Re: wide front for 656 revisited posted by K.B.-826 on July 25, 2006 at 19:11:04:
KB: Those Farmall front ends will actually bolt up and work on a 656 Utility. It will sit a bit high on front, but that can be overcome by larger rear tires.
Getting back to mounting a 966 front end on a 656, it was done by IH dealer and stabilizer cross member had to be modified. They replumbed the hydrostatic steering to the 966 remote steering cylinder. This happened as a result of a new 966 buyer wanting 4x4. The 656 front end was installed on a Farmall 300 using 300 center casting and stabilizer cross member. The guy with the 300 had both center control arms, and said it was a choice of turning short with strong arms, or steering like a stock 300.
