fast hitch/ hydra touch 560
Posted by gc ks on July 26, 2006 at 07:00:04 from (160.136.109.110):
I have a 560 Farmall diesel and the fast hitch does not seem to go as high as the one on my 350, when wou look at the cylender mounts it seems the cylender on the 560 sets a little lower than the on the 350. Also when I put the hydra touch lever in the fully raised position it grumbles like it could be starved for oil or it has reached the top most position, yet the cylender does not apear to have gone a full stroke. I have an operators manual for this but it says nothing on this. Thanks in advance on any help I can get.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
