Re: fast hitch/ hydra touch 560
Posted by the tractor vet on July 26, 2006 at 11:41:16 from (64.179.117.108):
In Reply to: fast hitch/ hydra touch 560 posted by gc ks on July 26, 2006 at 07:00:04:
well if your going to tinker on this tractor then i would get and I T manual for it . Change hyd. oil and filter . Then set down and read over the hyd section and check and adjust everything by the book. also having a hyd. pressure gauge and testing the hyd. system pressure then you sorta know if the system is up to spec. or not . The only way to tell if the pump is putting out the correct flow is have it flow rated by someone that has the equipment for this . But with the gauge it will tell ya if the system is comming up on pressure and you may luck out and only have to replace a pressure reg. spring . Myself i like to flow rate the pump first and see if i have the flow and pressure before getting into the pressure reg. valve .
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
