Re: Model A starter question
Posted by John T on July 27, 2006 at 05:55:04 from (66.244.90.5):
In Reply to: Model A starter question posted by Plant Doctor on July 27, 2006 at 05:24:21:
Doctor, When you say if you hit the starter switch with 12 volts she spins, are you jumping to the starter side of the switch or the input side and still using the switch to make her spin???? The obvious purpose of that question is to see if could be a switch problem. Even though you say a new battery n cables did you remove, clean n wire brush any n all other connections such as the frame ground and the starter etc cuz it only takes one bad connection to cause trouble. Even if the starter isnt stroung enough at 6 volts to crank over a piston on compression, it ought to grunt or try at least until a piston comes up on compression, does it do that or like never turn at all??? Ya dont reckon the starter rebuilder converted it to 12 volts when he did the rebuild???? maybe he picked up a set of 12 volt field windings by mistake!!!!!!!! I have no specs or data to answer your question of any difference in the starters, but I doubt there could be so much difference the regular 6 volt starter wouldnt still crank the engine over albeit slowly. For now (assuming the battery is okay like ElToro noted) I gotta go with a bad cable connection or a bad starter connection or a bad ground or else the rebuilder accidentally made a 12 volt starter out of it. John T
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
