Re: MORE QUESTIONS ON FARMALL 400
Posted by 26Red on July 27, 2006 at 07:54:52 from (170.92.100.2):
In Reply to: MORE QUESTIONS ON FARMALL 400 posted by JMUEHRINg on July 27, 2006 at 03:45:19:
A belt pulley off a M or Super M will fit. But you will have to take off the gas tank and hydraulic tank, and controls to install it... at least that was the way it was on my 300.
The gear oil has nothing to do with the T/A not working. The T/A clutch could be out of adjustment, but most likely the ramp roller are worn out. You"ll have to split the tractor to fix that one. As far as the level goes, there is a plug on the side of the trans to check. Gear oil is okay for the transmission, or you can use IH"s hytran which also can be used in the hydraulic system. You can add fluid on the side of the hydraulic tank just below the hydraulic levers.
Get a operator and service manual from Binder Books dot com. It is money well spent.
