Re: Model A starter question
Posted by Red Dave on July 27, 2006 at 08:35:19 from (24.104.94.34):
In Reply to: Model A starter question posted by Plant Doctor on July 27, 2006 at 05:24:21:
I overhauled my B (same engine) and used oversize, high compression pistons. I have 135+psi compression each cylinder.
6 volt battery, 1/0 cables, it spins over just fine.
If your connections are clean, bright & tight, yours should do the same.
Did your "professional" starter overhauler rewind your starter for 12 volts?
