Re: Stuck Super M
Posted by El Toro on July 27, 2006 at 08:37:23 from (64.12.116.65):
In Reply to: Stuck Super M posted by Soldner on July 27, 2006 at 06:07:46:
If everything else fails pull the head and pour some kerosene into the cylinders and set them on fire. Remove anything flammable and away from any building. Keep a good fire extinguisher handy too. The heat will free them and you won't need to pound on the rods to push out the pistons. Any soaking I would use transmission fluid. It freed an A tha had been stuck for years. I had to install a new sleeve kit. Hal
