Re: Stuck Super M
Posted by old on July 27, 2006 at 08:55:04 from (4.245.6.183):
In Reply to: Stuck Super M posted by Soldner on July 27, 2006 at 06:07:46:
I'd first check the starter as John said very common problem with Farmalls. All it takes is a weak battery and it will jam and lock up the engine. I f its not the starter whci it probably is they pull the plugs and blow out any water etc in the cylinders and pour in some tranny fluid in each one and let it sit a day or 2. The put on a good batterry and do fast quick hits of the starter botton. The starter will put out more torque then you can tring to spin a wheel by hand. Ive had very good luck unlocking engine this way.
