coil w/ internal resistor PLUS external resistor?
Posted by e-manhunt on July 29, 2006 at 08:04:26 from (69.179.103.137):
I've been chasing down an electrical problem on my 1940 M
converted to 12v, and got it fixed thanks to the people in this
forum -- a shout out to you guys.
Aside from replacing the coil, the condensor and points, I found
that the coil that was already on there had an internal resistor,
plus there was a resistor wired into the line running from the
ammeter. This doesn't seem correct from everything I've read in
this forum.
Except for various other problems, the tractor had been running
fine. I'm not so sure where my current problem originated, but
what problems would the external ballast resistor plus the
internal resistor in the coil have caused?
Thanks, everyone.
