M Water Pump Rotates Hard
Posted by chadd on July 29, 2006 at 11:29:39 from (65.54.155.56):
Just put together a water pump with new seals and a new felt seal as well. Now with the Retaining nut tight, the water pump turns kind of hard. It turned fine before I put the felt seal in. I coated the felt seal with a light coat of grease before I installed it in its groove. Should it go hard, or did I do something wrong? It seemed like it was a little thicker than the one I removed, but it is the part the dealer gave me. Thanks,
Chad
