Re: farmall A gear wine niose
Posted by Dave BN on July 29, 2006 at 19:05:52 from (64.12.116.65):
In Reply to: farmall A gear wine niose posted by brent schneider on July 29, 2006 at 18:11:10:
Those transmissions and final drives do make a whining noise. I would change the transmission fluid. The drain is in the rear, under the PTO shaft and the fill plug is by the shift lever. The level check is a pipe plug on the left side of the tranny behind the brake rod. You should also change the fluid in the final drives by removing the pans at the bottom to drain the fluid and clean the pans out. Put them back on with new gaskets and fill thru the level check plug which is just above the pan gasket. 2 gallons of 85W90 should be all you need. Dave.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
