Re: needing some parts and suggestions
Posted by El Toro on July 31, 2006 at 04:09:54 from (205.188.116.133):
In Reply to: needing some parts and suggestions posted by banjo on July 30, 2006 at 20:31:03:
You can buy sleeve and piston kits from this forum, some include bearings. You would need to have your crankshaft measured for wear to determine which bearings are required. Your local machine shop can obtain bearings too. To pull the damper pulley you should build a puller or have it made like Bigdog did for a Cub. Here's the web site for his puller. Hal
PS: To reinstall pulley place in your oven at 250 degrees and heat the pulley.
http://www.ytmag.com/farmall/messages/459316.html
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
