Re: stuck valve Farmall MD
Posted by Brad in WI on August 01, 2006 at 01:48:44 from (24.208.27.54):
In Reply to: stuck valve Farmall MD posted by lekwyo on July 31, 2006 at 20:43:19:
when it is missing is it always the same cylinder or does it jump around. The injectors may be bad (not opening at the right pressure or bad spray pattern) My 47 MD has a miss when it starts on diesel also but it clears up after a minute or two. My nozzle spray isn't the best but they open at the correct pressure.
Brad
