Re: 12-volt or 6-volt
Posted by old on August 01, 2006 at 11:13:40 from (4.245.2.21):
In Reply to: 12-volt or 6-volt posted by Derek Zwart on August 01, 2006 at 10:54:47:
Well if it has an alternator on it then you have about a 99% chance that its 12 volts. But if it has a genny on it you have a 50/50 chance its 12 or 6 volts since gennys can be made to put out the 12 plus volts need to charge a battery.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
