Re: B414 - converting to spin on oil filter
Posted by Fromjb2 on August 01, 2006 at 17:14:08 from (69.198.143.165):
In Reply to: B414 - converting to spin on oil filter posted by wkw on August 01, 2006 at 13:14:36:
Hi Ken, my Dad had B414,434,384, all same tractor but different sheet metal and a few minor improvements. They all had same canister oil filter. The only problem with this canister oil filter was the "O" ring that went on the base assembly, you had to lie on your back and dig the old one out with a sharp tool. The next problem IH used to send 3 different "O" rings with the replacement filter and you had to determine which "O" ring was the correct one for your tractor. If you didn't install the correct one it would leak. The final problem was you had to make sure the canister was seated properly in the grove in the base as you tightened it or you could warp the base assembly as my brother found out.
Now I am going to get jumped on for this tip but we only changed the "O" ring every second oil filter change and never had a problem.
Hope this helps
JB2
