Re: Farmall A want pull load
Posted by El Toro on August 02, 2006 at 07:55:57 from (152.163.100.65):
In Reply to: Farmall A want pull load posted by Russell S. on August 02, 2006 at 07:33:06:
I would check the valve lash and set them at at .017" cold. You need to check for any blockage in your gas line such as rust or dirt.
If you're using a fuel filter that's used with a fuel pump could be starving the engine for fuel. It may restrict the gas flow on a gravity
fed engine. Loosen the gas line at the carburetor and check for a good stream of gas. Hold a clean can under it to catch the gas. Are you sure you set the float level high enough in the carburetor? Hal
