Re: Farmall A want pull load
Posted by Russell S. on August 02, 2006 at 08:06:07 from (139.76.128.68):
In Reply to: Re: Farmall A want pull load posted by El Toro on August 02, 2006 at 07:55:57:
I thought i set the float level right. I think i'll check the timing first before i take the carb back apart. As far as the valves I just set those at .014 warm.
Also, I took the carb off my super A last week and put it on my A and it seemed to run a little better. I guess I need to check the float level. Thanks guys. Russell
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
