Re: Extra Horsepower 560 Diesel Can of Worms
Posted by Wardner on August 03, 2006 at 11:54:01 from (4.154.241.211):
In Reply to: Extra Horsepower 560 Diesel Can of Worms posted by robert searcy on August 03, 2006 at 10:03:18:
Somebody will come along and tell you how reset the injection pump governor and fuel screw. I am sure those directions are already in the archives if you are in a hurry.
You should bear in mind that the extra 600 rpm of the 660 is compensated through the planetary hubs. That means the extra 20 hp flows through what is essentially the same gear train, up to the axles, as the 560. There may be a ratio somewhere that is slightly changed. The IPTO is one and the differential may be another. I would be more concerned with the radiator. The 660 radiator is three inches taller.
