Need hydraulic HELP
Posted by Terry Miller on August 03, 2006 at 18:29:49 from (208.134.206.47):
I have a 300 ute and the 3pt cylinder ram was previously bent and cracked at the yoke on the end. It broke and had to replace the cylider with a used one I found for $50. I installed it and at first it did not want to work but finally did slowly. Then it had a chatter up and down. Now it is not working at all. The two steel lines that return to the pump were leaking at the o rings in front and we replaced those, and there was also a small pin hole at the back where they enter the housing below the seat. I had them welded twice but they still leak there. Does this have anything to do with the ram not working? It seames like the pump has lost its prime. I cant get the set screw on top of the pump to budge, was going to pour some fluid in to prime it. NOW WHAT? Terry
