Re: 1946 Farmall Super A Basic questions
Posted by Ron in Nebr on August 03, 2006 at 21:54:04 from (66.252.113.196):
In Reply to: 1946 Farmall Super A Basic questions posted by JD Lost in VA on August 03, 2006 at 20:49:07:
I'm not positive, but I think that the "Supers" didn't come out 'till about 53 or so...at least on the bigger tractors. So, assuming the A's were the same, yours is either not a Super A or not a '46. Does it have the touch-control hydraulic system? These came out on the Supers I think. If it does, there should be two arms that go out and up, used to raise or lower various implements, one on either side below the gas tank. There will be two levers that control these arms just to the left of the throttle, which is just to the left of the steering post.
As for controls- the throttle lever, like I said, is immediately left of the steering post. It'll have a sawtooth bracket that holds it in place. If it has the touch control levers, they have guides beside them with adjustable stops.
Other controls will be- on the left side of the battery there'll be a rod with a loop on the end that runs down to the carb. That's the choke. An identical rod on the right side will go to the starter motor- that, funny enough, is the starting rod. There should be a push-pull switch on the panel that the ampmeter is on, thats the on-off switch. A larger round rotating switch on that panel ran the lights. I'm sure you know what the gearshift is and where it's at. Last thing I can think of is to the immediate left rear of the left seat bracket there should be a small lever sticking up- that's your pto lever.
Most of the things(trans/rearend, final drives, steering box, etc. should have a fairly obvious plug on the sides of them that is for fluid levels. There's a larger plug on top of the trans near the shifter to fill it. Like previously mentioned, you NEED to get a manual if you're gonna run this tractor much. They can be ordered online through the links on the left of this page.
I'll let someone else tackle your mag questions! Good luck!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
