706: noise in gearcase
Posted by uncle fred on August 05, 2006 at 14:40:18 from (216.51.176.21):
I installed a new park brake adjusting linkage. To do this I also removed the platform, which meant removing the retaining springs for the brake pedals and clutch etc. After that I installed electronic ignition.
After I got it installed I went out to see how it was going to run. I got 50 yards down the road and I started to hear something in the gear train. It sounds like something is bouncing around and or loose inside.
In my haste to move onto the electronic ignition installation, I did not retain the linkage with cotter pins and it fell out. When I stopped as soon as I started to hear the noise I also noticed that the brake pedal shaft had moved out about an inch.
I don't know how the park brake mechanism works, but when the linkage fell off or the shaft moved out, what is in the inside that will fall off and move around?
I don't have a repair manual for this thing yet, but I am getting one on order. In the mean time I am looking for some advice on what the issue could be and where to access to look into it. I am guessing the plate under the platform will have to come off after more linkage is removed? THanks.
