Farmall Carb problems
Posted by Neil Wright on August 06, 2006 at 09:01:26 from (69.157.80.43):
Hi guys,
I’m having a bit of a problem.
I have a home made tractor with a Farmall Super A Zenith carb. (The engine is also out of a Farmall). It starts great, but when I use the throttle, it dies. I can keep it from dying by using the choke. The gas lines have unrestricted flow and there is no visible sediment in the gas tank.
In a nut shell, it has clean gas, but when I throttle her up, it’s as if I’m not getting enough gas.
So I thank you in advance, because I know you guys give great advice.
Cheers!
Neil
