Re: Farmall A Cooling System
Posted by tn terry t on August 06, 2006 at 19:33:32 from (152.163.100.65):
In Reply to: Farmall A Cooling System posted by Brad T on August 06, 2006 at 18:21:19:
the best way i know how to explain the thermo-siphon is its basicly like a perculator coffee pot so that gurgler is pretty much normal i have three of the A and superA tractors and all do the same thing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
