Re: Farmall A Cooling System
Posted by mbnok on August 06, 2006 at 19:39:21 from (216.226.31.40):
In Reply to: Farmall A Cooling System posted by Brad T on August 06, 2006 at 18:21:19:
The radiator could be stopped up, but, a thermo syphon system operates on its own at about 180 degrees. So there has to be sufficent expansion room in the upper radiator tank. The radiators had what appeared to be a tube down into the tank and the water level was to be about half way up in there. Then when you looked in there at operating temp the water would be raising and falling, and it would gurgle and make noises running or not. Don't add water until it gets down to the tubes, and if it gets down to the tubes pretty quick you probably have stopped up radiator.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
