Re: H Belt pulley seal replacement
Posted by Nebraska Kirk on August 06, 2006 at 22:04:41 from (207.91.30.73):
In Reply to: H Belt pulley seal replacement posted by Rock2000 on August 06, 2006 at 19:34:57:
All you have to do is remove the four bolts that are behind the flange that the pulley bolts to. The shaft will then slide out along with the bearings and gear, which are pressed on the shaft. You will then have to remove the bevel gear, one bearing and the spacer. The second bearing is secured in the bearing cage with a snap ring. The gear will have to be pressed off while the bearing is not quite so tight of a fit and can be tapped off with a hammer. Once the gear, spacer and bearing are off, you can then remove the bearing cage, which houses the second bearing and oil seal. Replace the seal, reassemble and you are home free!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
