Re: Farmall A Cooling System
Posted by gene bender on August 07, 2006 at 02:46:08 from (66.43.221.106):
In Reply to: Farmall A Cooling System posted by Brad T on August 06, 2006 at 18:21:19:
stick a temp guage reading in numbers should read around 170 when warmed up good. you did the rite thing by cleaning out the block as lots of get plugged in the nickle sized holes. is the overflow tube clean so whe water expands it can go out the overflow.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
