Re: Farmall A Cooling System
Posted by Brad T on August 07, 2006 at 05:39:26 from (206.137.240.6):
In Reply to: Farmall A Cooling System posted by Brad T on August 06, 2006 at 18:21:19:
thanks for all the good advise everyone. From what it sounds like, I may have put a little too much coolant in the radiator and it didn"t have room to expand, now I"m off to buy a temp gauge. thanks again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
