Re: B414 hyd. oil
Posted by Fromjb2 on August 07, 2006 at 20:54:10 from (69.198.143.165):
In Reply to: B414 hyd. oil posted by Scotty1 on August 07, 2006 at 18:42:20:
Hi Scotty, Hydraulic oil is checked thru the filler plug in the casting behind the seat.
From Operator's Manual: Hydraulic Oil, Remove plug and check oil level. Top up until the oil is level with the top of housing. Use Hytran hydraulic oil.
Transmission use 80 or 90wt gear oil. Filler plug is beside gear shift. Level check plug is beside brake pedal and floor board. Correct level is bottom of check plug.
Hope this helps
JB2
