ATTENTION ALL 300 350 UTILITY OWNERS, hydraulics
Posted by Terry Miller on August 08, 2006 at 04:34:24 from (208.134.202.37):
I am still trying to get my hydraulics and the 3pt working. Sunday I took the seat off and removed the vent to the hydraulic fluid housing, and put the air hose to it, and as soon as I did that I had instant pressure and the 3pt worked great, fast up and down, as soon as I removed the air it slowed and eventually quit again. Is it possible the screen is plugged, or something else? I started to remove all the bolts last night as to remove the whole cover under the seat and noticed the four tapped holes on top, must be for lifting it as it looks extremely heavy. My hyd. valves (2) sets are located just to my right as sitting, and look to be attached the that lid. Can those stay if I need to lift it? This all started when I removed the two hard lines to have a hole brazed,and replace the o rings, although it has always been slow.
