Re: 123 rebuild ?
Posted by Bob on August 08, 2006 at 11:03:56 from (64.21.249.40):
In Reply to: 123 rebuild ? posted by R Fink on August 08, 2006 at 10:44:42:
Packing the gears with petroleum jelly (Vaseline)
helps them prime quickly.
Where you're at now, you can try filling the crankcase WAY overfull of oil, cranking it until the pump primes, then drain out the excess oil BEFORE trying to start it.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
