Re: 123 oil pump
Posted by El Toro on August 09, 2006 at 04:24:26 from (64.12.116.65):
In Reply to: 123 oil pump posted by R Fink on August 08, 2006 at 20:10:21:
That may be your no oil pressure problem if that pickup screen is tilting away from the oil level in the pan. Should be a snug fit into the pump
as Keith mentioned. Hal
