Re: OT Dial up Computer woes
Posted by Hermit on August 09, 2006 at 06:52:27 from (69.21.48.55):
In Reply to: OT Dial up Computer woes posted by Hugh MacKay on August 09, 2006 at 02:45:06:
I'd check a couple of things. Is the phone line plugged into the line jack and not the phone jack on the modem? Have you uninstalled the drivers and also deleted the modem from the device manager, rebooted the computer then loaded new drivers? Did you check the modem options in the control panel and see if they're still valid for the new modem? Did you look at the Internet Options in the control panel for new changes? Hopefully, your computer wasn't on when you took the lightning strike or you might have some corrupted files on the hard drive. Good luck.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
