Re: OT Dial up Computer woes
Posted by Ron-MO on August 09, 2006 at 12:02:13 from (208.210.74.251):
In Reply to: OT Dial up Computer woes posted by Hugh MacKay on August 09, 2006 at 02:45:06:
I agree with what Allen says - have the phone co. check for noise, then reinstall the driver for the modem (no cost so far)....then I would put another new modem in it. Any spike from the line will take out the modem or cause problems. I have had quite a bit of experience and work with a 100 pc network and have seen most problems in one way or another. Allan is right those pc repair shops come and go and most of them (no, not all) have not a clue or any experience with electronics, and/or how a pc functions other than simply how to plug in a board. With that said I will never buy a pc from a local shop who builds their own piecemeal. Some may be fine, but most often they never really work right and often you end up paying for replacemnt parts within a year or two. I currently purchase pcs for work, and buy Dell equipment and rarely have a problem and if I do they replace the part (and labor) within one day at no cost and most Dell pcs come with a 3 year warranty. No, I do not work for Dell or get any compensation from them. I have started buying Dell refurb pcs and servers with good luck from them as well. My experience shows that you will end up spending more for the local "geek" who buids one than just buying a factory machine and it will run better/longer. Again, just my experience and your local guy may know what he is doing. Down my way it is usually some guy who found he could put one together and set up a shop.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
