Re: Super A with Exhaust Lift
Posted by CNKS on August 10, 2006 at 17:18:08 from (204.249.178.138):
In Reply to: Super A with Exhaust Lift posted by Mick Oz on August 10, 2006 at 16:10:58:
The Super A did not have an exhaust lift, the A did. If it has a large cylinder connected to the exhaust manifold it is an A. If it has two small levers next to the throttle, a reservoir under the gas tank, and a hydraulic pump below the distributer or mag it is a Super A.
