Re: Would Like Your Opinion
Posted by Robhkent on August 11, 2006 at 17:34:57 from (209.131.239.76):
In Reply to: Re: Would Like Your Opinion posted by Allan In NE on August 11, 2006 at 17:25:40:
Allan:
IH 610 one way disk. I don't know how your soil pulls, pretty hard from the sound of it. I have/will pull this 610 on some CRP (11yrs) with a stock 1066. It will make that 10 snort hard. I usually pull it in Lo 4th, occasionally Lo 3rd or Hi 1st. It does a good job down 4-6"
Other option is another bottom on the plow and a nice 1486....
Rob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
