Re: Would Like Your Opinion
Posted by jossette on August 11, 2006 at 19:21:00 from (216.114.223.197):
In Reply to: Would Like Your Opinion posted by Allan In NE on August 11, 2006 at 17:17:57:
Its probably so dry out there you will not get a crop of hay, but if you cut that grass down to the ground after first hard frost and then just give it a good discing, it should be fine. the wheat will kill most of it growing up and if you spray once it will go for ya. It works for oats out here.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
