Re: Would Like Your Opinion
Posted by Thack on August 11, 2006 at 19:27:12 from (4.160.252.209):
In Reply to: Re: Would Like Your Opinion posted by Nebraska Cowman on August 11, 2006 at 17:49:35:
I am with Cowman on this one.
Now we both know you will not do that...lol. I just don't think you'd be happy with the seed bed unless you disked both before and after plowing.
Back to no till,you could do it like my FIL...sorta no till. He just can't stand to be out of the fields so he will plow about 30 acres a year and disk about 80.
He used his 706 with a 5 bottom plow and 14' 370 disk.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
