Re: Would Like Your Opinion
Posted by Ksfarmmer on August 11, 2006 at 21:41:52 from (24.255.226.14):
In Reply to: Would Like Your Opinion posted by Allan In NE on August 11, 2006 at 17:17:57:
I recall my dad plowing some pasture ground. He hooked our M and MTA in series just to pull a 3 bottom plow. I was real little but I still remember both tractors really working hard.
I know later we would break up alfalfa. I don't remember how we did that, probably also with a plow. We had bigger tractors, an 806 and 1066 so it wasn't as big as issue.
I think I would try Round-Up and try to no till. I assume that your soil is dryland and not irrigated. CNKS got it right in saying get with your extension agent.
Sounds like you really want to use the plow though. Not much wheat grown in NE KS anymore.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
