Re: Rebuild My Own MCV Pump?
Posted by El Toro on August 14, 2006 at 07:19:28 from (205.188.116.133):
In Reply to: Re: Rebuild My Own MCV Pump? posted by Harlen Larson on August 14, 2006 at 04:58:13:
Doesn't your manual list the hydraulic pressure?
It should show where you would install a pressure gauge. Your gauge should have a higher range than the expected pressure so you don't ruin the gauge with excessive pressure. You may need to use a short piece of hydraulic hose that will withstand the pressure. You will also need the
tube fittings so you can connect the hose to the pump and to the gauge. Be careful around that high pressure. My manual only covers the lettered tractors and they had some pressure in the 1100-1500 psi range. Your pressure may be higher than this. Hal
